1. 监控事例的等待
select event,sum(decode(wait_Time,0,0,1)) "Prev",
sum(decode(wait_Time,0,1,0)) "Curr",count(*) "Tot"
from v$session_Wait
group by event order by 4;
2. 回滚段的争用情况
select name, waits, gets, waits/gets "Ratio"
from v$rollstat a, v$rollname b
where a.usn = b.usn;
3. 监控表空间的 I/O 比例
select df.tablespace_name name,df.file_name "file",f.phyrds pyr,
f.phyblkrd pbr,f.phywrts pyw, f.phyblkwrt pbw
from v$filestat f, dba_data_files df
where f.file# = df.file_id
order by df.tablespace_name;
4. 监控文件系统的 I/O 比例
select substr(a.file#,1,2) "#", substr(a.name,1,30) "Name",
a.status, a.bytes, b.phyrds, b.phywrts
from v$datafile a, v$filestat b
where a.file# = b.file#;
5.在某个用户下找所有的索引
select user_indexes.table_name, user_indexes.index_name,uniqueness, column_name
from user_ind_columns, user_indexes
where user_ind_columns.index_name = user_indexes.index_name
and user_ind_columns.table_name = user_indexes.table_name
order by user_indexes.table_type, user_indexes.table_name,
user_indexes.index_name, column_position;
6. 监控 SGA 的命中率
select a.value + b.value "logical_reads", c.value "phys_reads",
round(100 * ((a.value+b.value)-c.value) / (a.value+b.value)) "BUFFER HIT RATIO"
from v$sysstat a, v$sysstat b, v$sysstat c
where a.statistic# = 38 and b.statistic# = 39
and c.statistic# = 40;
7. 监控 SGA 中字典缓冲区的命中率
select parameter, gets,Getmisses , getmisses/(gets+getmisses)*100 "miss ratio",
(1-(sum(getmisses)/ (sum(gets)+sum(getmisses))))*100 "Hit ratio"
from v$rowcache
where gets+getmisses <>0
group by parameter, gets, getmisses;
8. 监控 SGA 中共享缓存区的命中率,应该小于1%
select sum(pins) "Total Pins", sum(reloads) "Total Reloads",
sum(reloads)/sum(pins) *100 libcache
from v$librarycache;
select sum(pinhits-reloads)/sum(pins) "hit radio",sum(reloads)/sum(pins) "reload percent"
