BlankWorks4.0测试及应用详解
2009/3/25    来源:e-works    特约撰稿人:王毅
关键字:CAD  SolidWorks  BlankWorks  网格处理
BlankWorks是一个基于SolidWorks环境快速展开工具,SolidWorks2007之前的3.0版本是一个好很好的工具,但是BlankWorks3.0在SolidWorks2008以后的版本里不能用了,不久前,FTI终于出了可以应用在SolidWorks 2008 2009下能用的4.0版本。本文主要介绍了BlankWorks4.0的界面及其相关的测试
    下面我们正式看4.0的界面及其相关的测试:
1 工作界面:
图1 工作界面
2 菜单:
图2 blankworks菜单
3 分析步骤详解:
    感觉比起blankworks3.0 ,功能更简单了,不用再手动的处理网格了,程序全自动的处理了,分析的步骤也更简单了,一共6步:
(1)Click the BLANKWORKS icon  on the BLANKWORKS Toolbar, or select BLANKWORKS > Setup from the main SolidWorks menu.
    点菜单或者工具栏中的“setup”按钮,启动设置界面。
图3
(2)Select all surfaces to be flattened, it can be either the entire model or only the flanges (flange unfold).  These surfaces can either be top, bottom, or mid-surface.
    选择要展开区域的曲面(一定要是曲面,可以是上下表面或者中面。)。
图4
(3)Define any Constrained Edges and any Support Surfaces (curved binder / unfolding surfaces) as applicable.
    定义对称边线。和展开基准平面(没有就算了)。
图5
(4)Define the Material Type & Thickness, as well as the Thickness Direction.
     定义材料、厚度,最好还有厚度的方向(中间面就免了)。
图6
(5)Define the forming coordinate system (press direction) or select the Auto Tipping function. The Z-axis of the defined coordinate system will be used as the press direction during the analysis. The default tipping direction is the global Z-axis.  If the default axis is NOT used, the blank will be created on the X-Y plane of the defined coordinate system.  Define the forming process as either Draw Die or Form Die.
    定义展开的坐标系(冲压方向)。全局坐标系的Z轴为默认的自动展开的方向,假如此项没有定义,则自动会在XY基准面上展开。
图7
(6)Define the mesh generation parameters by selecting one of the three options available: Low, Medium, or High.  The default setting is Medium. Select the check box for Fill All Holes if you would like the holes to be filled in during meshing and for blank development
    定义网格划分的质量,默认为良好。(还可以指定自动补齐所有孔)。
图8
责任编辑:杜凯
